LCD Backlight Upgrade
This topic is closed.
  • LCD Backlight Upgrade
    What is the goal of this project?
    Well as everyone knows the backlight on the Lilliput and Xenarc screens are quite inadequate.
    So with help from Scouse Monkey and others, we are trying to find a solution that will give us a cheap and easy way to upgrade the backlighting system in our screens without having to pay anywhere from $500 to $1000 for what we feel might be an easy fix.
    Not only are we going to be upgrading the brightness we are also working on a auto dimming circuit that will use a phototransistor to adjust the level of brightness without any user intervention.
    Current Information on the project.
    CCFL Project Percent Completed [#####_____] 50%
    CCFL Project Status = Waiting for final designs from china
    LED Project Percent Completed [ON HOLD]
    LED Project Status = We have put the LED project back on hold, turbocad is currently testing LED's so we will see what he comes up with.
    07/27/05 Update
    Going back and forth with china again for a 2nd redesign of the CCFL tubes. Hopefully will have 3 or 4 sets of samples within a couple weeks.
    Now back on the search for inverters, but as this design uses lower power tubes it should be easier to source the correct inverters.
    7/15/05 Update
    Well everyone we are still here, due to the issues with finding the correct inverters we are currently revisiting the LED backlight modules
    7/12/05 Update
    just a little status update, we are still here and still working away at this project. It's just been really hard to find the parts we need at a decent price.
    I did find something interesting in my testing tonight though, you can use a Panasonic screen on a lilliput controller! Which is awesome news now I can test both types of screens on the same controller.
    5/27/05 Update
    The backlight control is coming along nicely. I almost have the code finished, next comes the actual circuit.
    We have started a thread to document this process as well
    http://www.mp3car.com/vbulletin/showthread.php?t=50953
    5/23/05 Update
    Just wanted to give everyone a status update, i'm still here, I just dont have any working controllers at this point to test with. So i'm just waiting to hear back from DigitalWW. I am also waiting to hear back from ERG about purchasing the inverters we need.
    5/19/05 Update
    Well after blowing out my last test controller, the hunt is out for a replacement.
    After contacting ERG about inverters, looks like they have a unit that will do the job nicely. So hopefully I can purchase a few and get back to testing
    5/11/05 Update
    Well after testing with good results, now the search is out to find better inverters. Next up is going to be the heat test where we will find out if the display can handle the extra heat for a extended period of time.
    more pictures on posts 166 and 167!
    5/10/05 Update
    The tubes are in!! see posts 77 and 94 for pictures!
    5/8/05 Update
    The CCFL tubes and the Inverters have shipped from china!
    So they are in-transit, which means I should have them by mid week.
    I also received the ultrabright white LED's today for testing.
    5/7/05 Update!
    I received a e-mail from china, they are finishing up the quality control testing of the tubes. So they should be on time for shipping on Monday the 9th.
    Information website is up!
    i'm going to be posting all of the test result images as well as guides to taking your screen apart there
    http://www.jcdsystems.net/ccfl.html
    4/29/05 Update
    Due to the holiday in china the tubes will not ship until the 9th of May
    We currently have 2 different sizes of tubes coming; we have a 2.6MM tube and a 4.1MM tube.
    We are currently working on a circuit that will provide automatic dimming for the CCFL's. So at night no adjustment would be needed.
    The brightness upgrade will have new a new inverter so the built-in inverter that is currently in the screens will not be used.
    Project FAQ
    OMG How are you going to control the brightness for night use?
    We will have a couple diffrent options for dimming
    1. Photocell mounted aound the screen bezel (will recomend people look at their dash in sunlight and mount it in the spot where most light falls on the screen).
    2. Manual pot to turn up/down the autodimmed levels - ie the screen will still auto adjust but if it's not quite right you can alter it.
    3. manual mode to prevent any auto adjsuting
    4.-OPTIONAL-PC control so the frontend can increase the brightness for some apps or you can build a nice OSD fo control the autodimming if you dont want to have buttons.
    5. The manual adjustment might be done with 3 buttons. ie one for up, one for down and one to toggle auto on or off.
    What screens is this being developed for?
    Well right now we are shooting for the two main types of screens.
    7" Lilliput which contains a Hitachi LCD panel.
    7" Xenarc which contains a Panasonic LCD panel.
    If this design works we will move on to the bigger style screens.
    What are you using to do the upgrade?
    We have been going back and forth between CCFL backlights and LED based backlights. For right now we have settled on CCFL tubes for our backlighting project. Because of their price and ease of use.
    What will this be replacing and will it require alot of changes to my screen?
    What were are trying to end up with is that you will be removing the stock CCFL and the stock light guide and just putting the new tubes into the stock LCD housing. So the only thing you should have to do is cut a few small holes in the side of the LCD for the 2 extra tube ends to come out.
    How bright is this going to be?
    Well everything right now is a guess, but we are hoping for the 800 to 1000nit range. Untill we get the tubes and test them we really dont know.
    How much will it cost?
    The final cost is unknown at this time but we are aiming to keep it under the $100 mark.
    Will this be a kit or will you be offering to do the upgrade?
    Well after we test the solution, it should be available as a kit. But later on down the road we might go for installing the kit for people.
    I'd like to make a donation. Who should I send it to?
    Just go to this address and use the donation button located there.
    A special thanks goes out to all that have donated, you have made this much easier on me
    all listed in no particular order
    Quattro
    old_lou
    tj!2k4
    MaleBuffy
    migel628
    04scooby
    sonex293
    Blue ZX3
    JC-S60
    NUIpIsqo
    if I forgot to list you i'm sorry!
    Where can I find information about the history of this project?
    This is the timeline for the project
    4/12/05 Project Started
    4/15/05 Contacted company in China that produces custom CCFL Lamps
    4/22/05 Design sorted out with company in China, Payment sent for set 6 sample tubes.
    The original thread started here.
    http://www.mp3car.com/vbulletin/show...threadid=47567
    肚子笑痛了
    S60 Install
    Reserved for new photos
    肚子笑痛了
    S60 Install
      Posting for email updates, If i can help guys let me know. I do have some pretty good resources. I have access to a protpype shop with 2 CNC machines and MFG area with 2 10000 class cleanrooms
        This is bloody sweet! So long as I don't knacker my display installing it...
        *subscribed*
          Good luck guys. I can definitely see an advantage is improving the back light.
          When you get it working you can definitely count me in.
          Mind Scream out
            Are you guys trying to make this fit inside the current Lilliput/Xenarc housings? That's the only bit of info I was really unsure of...
            "I'm a dick!"
            "I must seek knowledge and it's bastard son truth" - The State
              faq updated
              肚子笑痛了
              S60 Install
                Thanks, I will do just that.
                肚子笑痛了
                S60 Install
                  *subscribed*
                  Great work...definitly thinking about making a donation..!
                  Next in line: RRMedia v2.0
                  DFX 5.1.1 Skin
                  Appstore Link
                  My RideRunner Plugins
                  RRMedia
                  RRExtended
                  DFXVoice
                    be careful, it will not be as easy as you wished
                    I have done a lot for this kind of upgrade before and do not get satisfried result
                    1.TFT lcd is not a kind of film like panel which you can add as more light as you like, at the same time to strong the back-light, you have to do some on TFT drive timing, otherwise, the result would be too "white" and acting as a lamp....
                    2.the heat should be lead away from LCD as fast as possible, otherwise you would find out the yellow "shape" after 10 or more hours...
                    3.according to my reserch, "side mount" would be better then "back mount" , and please do not expect brighter than 800
                    4.a Chinese company have done a lot on this field, the result is very expensive model. I will post all their documents
                    sorry for my english and good luck!
                      her is the web address of the company
                      http://www.superbright.cn
                      I do NOT recomand anyone to buy their expansive models
                      and here comes the details
                      (sorry, the doc of their offer is too large to attach 680K after zip)
                        I'll host the file if you want.
                          Thats all very well but if we don't try we don't get anything!
                          But...i know of a Uni research project were they have dome something similar to what we want to do and they have made fighter cockpit brighness (well over 1000nit) screens! And that was a 4th year uni project (ie quite basic project with minimal resources and I came up with the same design issues and solutions they came with after 6 months of work in a couple of hours).
                          Heat willbe an issue and it is one we are not taking lightley. Even LED systems can get hot. I would love to use LEDs but I know how many we would need and the diffusers would be expensive. CCFLs are much easier and cheaper.
                            Are you planning on sticking w/ 7" LCDs or would this project be applicable for 8" screens as well?
                            "I'm a dick!"
                              well if the project works, i'll be happy to redesign it for the 8"
                              肚子笑痛了
                              S60 Install
