Lilliput Blown Up / damaged need help
  • Lilliput Blown Up / damaged need help
    Hi Everyone.
    i had a 7" lilliput touch screen fitted in my car but it fell out of the dash as i set off.
    i didnt think anything to this but then when i tried powering up the screen the next day it just doesnt do anything.
    the red light on the front pannle does not light up when plugged in.
    i was wanting to know if anybody else has had a similar problem with there screens.
    i think its just the screen or a cable as when i plug in the usb to a spare computer it sees the screen and want drivers for it.
    Any Help and i would be greatful otherwise its off to lilliputuk.com for repair
    Thanks Everyone
    Did you even think of searching?
    Try reseating the smaller flat ribbon cable
      C'mon now, you know noobs don't understand that concept yet
      "I'm a dick!"
      "I must seek knowledge and it's bastard son truth" - The State
        Got It Fixed
        I got the power cable in the wrong way around it turns out. blew the fuse and the reverse polarity protection circuit. so i gave it to a m8 and got it fixed for free.
        Thanks Anyway
          Fuse blown lillput 7"
          what is a "m8" my lcd also has a blown fuse. the fuse says a symbol of a triangle with a "T" inside witha a lil line on top of the T. also it says KOAC 1A.. can anyone tell me what these things mean??
            lol
            m8 is an english term for mate.
            And that means friend or bud and not your fuk***** kind of mate
            1A is the rating of the fuse, meaning 1 amp, you MUST replace it with the same value
              what about the letters? and also what kind of fuse? does anyone know where i can get the same one. i have gone to digikey but too many different kinds. it looks like a SMD fuse. i have a pic of it? i don't know if it's a fast or slow acting.
                no one knows
                  it is a fast acting SMD fuse, digikey has them, and I believe Armen from Digitalww has them as well.
                  but like some others I just soldered a regular fuse holder to the existing pads, that way I can use standard fuses instead of having to buy the darn SMD fuses
                  肚子笑痛了
                  S60 Install
                    thanks i contacted armen and it like 3 dollars
                      good you found one
                      肚子笑痛了
                      S60 Install
