Using s-video on MII 12000
  • Using s-video on MII 12000
    While i am waiting for my new monitor, i thot i would install my system with my pioneer in dash screen. I had problems using the tv out, and by searching found that there was a problem which could be fixed using a resistor.
    I also read that you could use a svideo to rca adaptor, that this should work ok. I have tried this but still cant get the desktop to show on the pioneer screen. The only way i can get it to work is if i have a vga monitor connected at the same time. If i unplug the monitor the picture stays on the pioneer but when i reboot i am back to the same problem.
    I have tried changing bios settings but still cant get it to work. Am i right in thinking that by using a svid to rca adaptor i am not affected by the problem of insufficient resistance?
    Anyone offer any help??
    Epia MII12000, 256MB RAM, 40GB laptop HD, slim DVD/CDRW, M1-ATX, 8 in 1 card reader/writer, Pioneer indash screen (waiting for K301 touchscreen)
    There is a workaround for this vga problem. It has something to do with bios wanting a vga screen plugged in during post. You can use a vga terminator (i think thats what its called.) It is basically a vga connector that puts a loop on some of the pins, fooling the computer into thinking there is a monitor connected. Have a search for the VGA loopback/terminator thingy
    "A conclusion is the place where you got tired of thinking."
      Thanks for the suggestion, ill look into it.
      But i think the MII 12000 can display on svideo without a vga monitor present.
      In bios where you select display device, it has the option for tv only. This is the setting i have tried, with display type as svideo but i dont get any picture. If i select crt + tv then it works ok as long as the monitor is connected aswell.
        Look here (Bottom of page) and here
          Thanks, will give this a try
            I have an EPIAm m9000 and I use the resistor trick to get the screen to work without a monitor. Go to radio shack and get an RCA y cable, buy some resistors (I don't know how many ohms, mine might be around a 100 but I don't exactly recall.) Put the resistor in one end of the y on the RCA cable, the other end goes to the computer like normal. The resistence should tell the screen to enable without a monitor attatched.
            You can also test and see if this is your problem by hooking up your computer to a TV and seeing if the video out automatically gets enabled. You might have to try a couple of TV's becuase not all TV's end up putting the resistence on the RCA cable to tell the motherboard it's there.
            Good luck.
              I tried the resistor on the rca cable and it almost works. I get the display from boot and can see bios setup screen and windows desktop aswell.
              But when i installed the vga drivers i only get the boot screen, not the desktop. The only way i get the desktop is if the monitor is connected aswell. In the display settings the tv option is greyed out so its still not detecting the screen.
              I tried it on another tv and it works fine. BTW i am using a 0.25W 68ohm resistor as this was the closest they had in stock. Could this be why its still not detecting it, but as i say it shows the boot screen.
              Maybe i will just uninstall the vga drivers, then it will work with resistor but without the monitor.
                Try a stronger resistor. I think mine is around a hundred ohms or something. The drivers in windows do have the enable vga output that shouldn't need a monitor attatched to for it to be enabled. It's a little wierd that you say it is greyed out but maybe VIA changed the drivers a little or something.
                  Thanks, i will try another resistor
