how do you output video from a laptop to a lilliput?
  • how do you output video from a laptop to a lilliput?
    i am getting a laptop and would like to send the video to an in-dash lilliput screen. how is this done?
    Steve Davis
    www.CraniumDesigns.com
    The laptop should have vga out some also have composite (rca) which the lilli can take.
    Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
      Most of the laptops have a VGA connector in the back......... use it to connect the lilli
      stay away of the composite (no good for text and such).
      Also you may want to disable the lcd of the laptop thru the bios.
      RexBruMet Skin for FrodoPlayer
      Nissan Aux-in MOD
      Originally posted by bgoodman
      We're an international forum, post in whatever langauge you like.
        so its nothing complicated? just hook up a cord? so the lilliput takes a standard vga insert like most cimputer monitors?
        Steve Davis
          Exactly, but well NOT exactly.
          If you buy a VGA Lilliput then YES you just connect it like any other computer monitors.
          If you buy a NONE VGA Lilliput, you must use composite out put and some Laptop may not have that output (composite and/or S-Video)
          Y2K Accord Dell GX150
          EmoRebellion is a SCAMMER
