Rewiring IR on Lilli
  • Rewiring IR on Lilli
    Ok i'm installing my lilli into my sunvisor and have no room or need for buttons, all i need is the IR sensor to work.... I was wondering if you can use the one that came with it, just snap off the pieces of the board the buttons are on around the IR sensor and solder wires to the connections of the sensor...
    or should i pick up another sensor some where, and if so what kind
    thanks
    Debating on installing a carpc in my Jeep.....
    or just de-solder the ir reciever? you will prob end up ******* the whole board up if you try snap part off.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
      ahh good idea, dont kno why i didnt think of that
        yeah just desolder it dont snap it off its a ***** to desolder tho so have fun make sure u get the 3 wires connected right or it wont do **** for you test it before putting it in!!
          now, i know that...
          PIN 8 = IR PIN 2
          PIN 9 = IR PIN 3
          PIN 10 = IR PIN 1
          But i dont know which pin is labeled 1, 2, and 3 on the ir itself
          anyone know which pins on the ir are wired to which pins on the ribbon connector?
            follow it back on the pcb
              middle one doesnt seem to go newhere, and the others seem to goto 10, 11... and that doesnt follow the wiring guide that you posted in your write-up
                http://www.tmz.com/wrx/lilliputlcd.html
                  Pin 8 Phototransistor Pin 2 (GND), Switch Common & LED Cathode (Red & Green Only)
                  Pin 9 Phototransistor Pin 3 (Vcc) and Blue LED Anode (all 7) Common
                  Pin 10 Phototransistor Pin 1
                    dont tap it from there desolder the ir thingie from the board itself and extend it off the board its easier and safer!
                      yea i desoldered it last night and put some wires on it, just gotta solder em to the pins on the main board now
                        I tried to extend the sensor off the board but something went wrong and when i reconnected it, it never worked. Is it possible that the heat from the soldering iron mest up the IR reciever, if so where can i buy a replacement.
