Where and what plug is this PLEASE just let me know
  • Where and what plug is this PLEASE just let me know
    ok so i just bought the 2005 model lilliput 8 inch touch screen .
    there is a 15p sks input jack which connect into the monitor and the normal 9 pin vga conector which conects into the back of the computer.
    but i am looking to extend the cord and in the middle there is male and female 9 pin connector that looks like an S-video connector but it wont conect to svideo cable from top to bottom the pins go 3 pins then 4 pins the 2 pin rows, so there is 9 total pins
    Where do i buy another so i can mount my monitor better
    thank you
    or it may also be btter if i could find maybe a 5 foot calbe that has this 15 pin sks cord which is going straight into the monitor
      under the FAQ's it says
      Inputs
      SVGA, RCA Composite, & VGA
      If you want to extend the video/touchscreen breakout cable (the one that gives you your VGA plug), use a "9 Pin Mini-Din" cable. This may also be referred to as a 'bus mouse extension cable'. Don't confuse this with a normal PS/2 keyboard or mouse extension cable, they don't have enough pins and have a different shape inside.
      Example cable: http://www.computerplug.com/cable_m...us-ext-tech.htm
      but when i click the link i still cant find the cable please direct me thaks
        Inputs
        Try looking at my post below that one....http://www.mp3car.com/vbulletin/show...9&postcount=24
          there ought to be another smilie to go with , , and
          that tells people to check the damn store. if you're going to ask where to buy something, make sure you see if the mp3car store sells it before you bother asking...
          But don't take it from me! here's a quote from a real, live newbie:
          Originally posted by Viscouse
          I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
          eegeek.net
