SUPER 7" Touch VGA screen, problem with drivers- same apps as Lilliput?...
  • SUPER 7" Touch VGA screen, problem with drivers- same apps as Lilliput?...
    I bought a 7" SUPER (Branded LCD) on Ebay about a month back. Screen looks GREAT! Problem I am having is when I install the touch drivers. The applications look the smae as the Lilliput which leads me to believe it is just a repacked version. I follow the directions, leave the USB unplugged, run setup, don't check PS/2, it installed, but then when it goes to install the drives the machine freezes. I can later force it to install by doing an "Update Driver" once the USB plug is plugged in, and it seems to go on fine. It says it finds a controller on COM 3, but inside the TouchKit app there is nothing listed. I then go to Add, and the App crashes. I have downloaded the latest drives from Lilliput but that won't even find a controller, but the drivers will work for the USB device.
    Any thoughts?
    Thanks!
    Tom
    same problem here too with a Lilliput 8"
      you gotta delete all everything that was installed up to the freeze which is a lot and hard to find because i think some of it is in the systym reg keys... Best bet is reformat hard drive and do a clean install... thats what i did when i messed up and it froze on me
