Which MOBO to run a high spec graphics card
  • Which MOBO to run a high spec graphics card
    I would like to know if anyone knows of a mobo that has a agp slot or comes with a high spec graphics chip capapble of running the games like doom3 or hl2? i also plan to run a 17 inch tft screen, i did wanna try and install a full size pc but dont like the idea of running a power inverter as i got so much stereo equipment as it
    any help is muchly appreciated tnx in advance
    Robin
    Do you know what sometimes i astound my self at how stupid i can be lol!! so i can use a pci g.card instead lol, ok so changed question now if i use a pci graphics card will i be able to disable on board graphics chip via bios?
      Yupp, you should be able to disable the intregated video and enable the other on the PCI
      Chech your bios configuration.
      Ampie Case
      M1-ATX 90w
      EPIA ITX 1,3Ghz, Firewire
      80 GIG SATA
      512MB
      7 TFT Touch Super
      Pioner Slot in DVD-RW writer
      108 Mbit Wireless Lan
      100 M Bluetooth Range
      //Power Nisse
      My Betasite -> http://haagen.se
        even if you can't disable via bios (and some cant') you CAN disable /un.install in XP's DeviceMgr
        •Micke
          Currently there is NO DC-DC PSU could handle the spec you want.
          Good luck
          Y2K Accord Dell GX150
          EmoRebellion is a SCAMMER
