M1-ATX sufficient enough for this setup?
  • M1-ATX sufficient enough for this setup?
    I will connect following
    VIA EPIA SP13000, m/Via C3 CPU 1300MHz Mini-ITX,DDR400,VGA,Tv-Out, Firewire
    Crucial PC2100 DDR-DIMM 512MB CL2.5. Non-parity, 2.5V, 64Meg x 64
    SATA - Samsung SpinPoint M40S 80GB 5400RPM SATA2 2,5" 9,5mm
    IDE – Slimline Panasonic DVD ROM/Cd RW 4x
    USB - A 7 Avator 7 tft Touchscreen, screen and usb connected
    USB - 3COM OFFICECONNECT 11G 108MBPS WIRELESS WLAN
    USB - GPS, The gps has batteri but recharges via usb.
    USB - Remote controll later on
    USB LCD from http://www.crystalfontz.com
    According to power calculators its on the edge of wattage.
    "maybe" need the "opus 120
    solution
    Maybe a OPUS 120 will do it! Just have all components in the ampie case and install the OPUS beneath it in a box. Drill holes for the wires etc
    Ill go for that solution =) IF the M1 isn`t Sufficient enough.
    What do you think?!? =)
    Ampie Case
    M1-ATX 90w
    EPIA ITX 1,3Ghz, Firewire
    80 GIG SATA
    512MB
    7 TFT Touch Super
    Pioner Slot in DVD-RW writer
    108 Mbit Wireless Lan
    100 M Bluetooth Range
    //Power Nisse
    My Betasite -> http://haagen.se
    You may post new threads
    You may post replies
    You may post attachments
    You may edit your posts
    You Might not Delete your post ?!?
    "if you asks a power question in a lcs section" Sorry guys
    Ampie Case
    M1-ATX 90w
    80 GIG SATA
    512MB
    7 TFT Touch Super
    //Power Nisse
      edit allows you to delete
      Peugeot 206 1.4 HDi
      Intel Mini-ITX Mainboard
      Celeron 1.2ghz
      256mb DDR-2 533
      80gig 3.5" SATA HDD
      Sb Live 5.1 w/ KXProject Drivers
      M2-ATX
      8" Lilliput TS LCD
      100% installed and working :D
        how? i tried to delete all chars and then it said you must have minimum 1 char
        Ampie Case
        M1-ATX 90w
        80 GIG SATA
        512MB
        7 TFT Touch Super
        //Power Nisse
          The option to delete is at the top of the edit page.
          How about the Wiki?
