Where to put an LCD?
  • Where to put an LCD?
    Hi all,
    I have a 94 BMW 318is, I have bought an LCD from Timeline (Don't start), I don't know where to put it. I wanted to put it under the a/c but the dash-hole isn't big enough. if anyone has done this, or knows what the inside looks like, please help.
    Alon
    Still Building the rest
    can you give us any pictures of the inside of your car? that would greatly help since very few people will have that type of car.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
      ok, well the post above says it all
        The area under the air conditioning controlls looks perfect to me. You could fit a 12 inch lcd down there. Your screen might not fit in the hole for those 2 pockets and clock but it dosent look all that difficult to modify. You might try cutting the hole out to perfectly match the screen size and position the Lcd behind that panel. Whenever i modify my car though, i use a part from the junkyard and keep the original.
        mike
        91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
          i want to mount a 40*4 LCD panel but i dont have where. if it was a full lcd that wouldn't be a problem.
          I am also thinking of selling my car soon so i don't want to make any holes or what not.
          Alon
            if you just wanted a character based LCD the little hold above the bigger one in the compartment below the air conditioning controls looks about the right size, you should be able to put something in there no problem. failing that, the area below it is bigger and should fit about anything that you'd want.
            I don't think the entire area could fit a 12" screen however...
            I'm just going to have a 10.4" screen mounted on an arm at steering wheel level.
              the bottom hole i smaller than the lcd smaller by 2 or 3 mm. can i hsave the lcd?
              or can i disconnect the lcd from it's board, and re-connect it with a ribbon cable?
              thanks.
              alon
                Telek: How much did the screen cost ?
                  I bought two, and with shipping it came out to $100 (US). That was when i was in the US.
                  Alon
