Lilliput doesn't go into VGA mode anymore
  • Lilliput doesn't go into VGA mode anymore
    I plugged in my Lilliput 7" touchscreen to through VGA and enterd the code on the remote exactly in the "Auto Power On 619 Lilliput - Programing Guide" post.
    Well everything went well, then after it saved the settings, my screen went blank and then a little box came up and said something like "no C-video connected". It's now like it doesn't even try to detect my VGA input, even though its hooked up. I can connect the component video and it detects it, and I can enter into the menu with the code in component video mode, but the VGA mode doesn't work anymore!!
    I checked and double checked my connections and everything seems connected correctly. I don't think it's my connections anyway since it stopped working right after I saved the "auto power on" code.
    I looked at the codes and there isn't anyway to disable the vga mode, is there? I tried putting in different codes and seeing if it would work, but so far I can't get the VGA mode to work.
    If anyone has any ideas to how I can get the VGA mode back, I'd appreciate it!!
    Dan
    1997 Corvette
    Bump.
    Does anyone know if I somehow could of accidently disabled the VGA input somehow? It detects composite video just fine but doesn't detect the vga input anymore.
    1997 Corvette
      I'm having the same problem. Did you ever get this resolved? Thanks!
      Jonathan
        factory reset ???
        There is probably a lithium battery, take it out for a few hours
          Any idea where the battery is on the screen? Thanks.
          Jonathan
            hmmm there might be reset code with the remote
            PC Components:
            My work log
              Not sure what you mean. Could you be more specific, please? I think the error I'm getting is, "no c-video 1"
                bump.
                  bump!
                    Jonathan
                    Nope. I hope I can figure it out here sometime though. I really don't want to be forced to use component video. I'll let ya know if I figure something out.
                    1997 Corvette
                      try this http://www.mp3car.com/vbulletin/show...lilliput+codes
                      PC Components:
                      My work log
