VGA LCD - Blurry with new C136 Epia 800
  • VGA LCD - Blurry with new C136 Epia 800
    Hi there,
    I use to have a P3 system hooked up to an inverter and the image on my "Avatar" aka "Super" Vga monitor was fine. I then hooked it up to my new computer, a C136 with Epia 800, P1260 regulator and the image is all blurry. In fact when I turned it on for the first time the monitor said "signal out of range". I then went into safe mode and changed the settings.
    Even after doing that the image is all blurry. I tried auto adjust, but nothing. Do I need to install some new drivers or something? I just can't work it out. It is hooked up with a different VGA cable extension than before, which is really fat, so I might try changing that.
    The computer had XP installed from the previous owner, so maybe I should start fresh with a new install???
    Any help greatly appreciated,
    Alex V
    -Alex's CarPC
    Gain 7" monitor
    EPIA 800 in Travla C136 case
    Map Monkey GPS Nav
    Bluetooth
    USB Tiny Keyboard
    GPRS Internet
    Reverse Camera
    Just to let everyone know I fixed the problem. It was the infamous din connector. I really should have thought of it before.
    Alex V
    -Alex's CarPC
    Gain 7" monitor
    Map Monkey GPS Nav
    Bluetooth
    USB Tiny Keyboard
    GPRS Internet
    Reverse Camera
