Info on Allens TFT To VGA Converter
  • Info on Allens TFT To VGA Converter
    I know may people have gotten this controller and Im sure some of use have gotten it working. If there is anyone out there that has any documentation on how they set up the controller please let me know. Just want some info before I try to break my new toy.
    I got mine working, what kind of info are you looking for?
    Steve
      like a data sheet
        xcuetippx you got mail
        www.sounddomain.com/id/2000mp3ranger
        Mp3 player - 10.4 Allbrite Gigabyte GA-71XEH , 700 mgz t-bird , coolmaster fan , 2x 128 ram + 1 512ram , ATI-RAEON RV100 ,on bd sound , Linksys Wireless-B usb network adapter , 20G IBM TRAVELSTAR
          I Would Also Like To See Peoples Finshed Product. Just To See What Everyone Did
            Would someone please fill me in about this controller?
            Impee3 Car Player
              can you please email me the datasheet - allen you got to get me one of these controllers - maybe two
                I wouldn`t mind the datasheet either
                Im currently in the process of wiring the controller to the LCD
                My Setup
                  Can some one please email me that datasheet.
                  Thanks alot guys!
                  Fosgate
                  System Comp V3 - In progress.
                  Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
                    As many of us have I got this controller from Allen. He did send me a picture of the cable that I need from the card to the VGA Output. I just wanted to get as much info on this card as I could so I emailed the maker of the card. This is what they said.
                    Hello,
                    All that I can tell you about this board is that it is a component
                    to our 10" display. The VGA to TFT controller board is not a resale part
                    therefor there is not a manual for the board. All schematics and design
                    related materials are property of Datalux Corporation and since this is a
                    current design this material is not available for distribution. The board is
                    hardware driven and output only, no drivers are used in connection with this
                    board. I do not have any additional information available that can help you
                    with your project.
                    Respectfully.
                    Jon P. Christian
                    Datalux Customer Support Representative
                    (540) 723-4230 ext. 16
                    If anyone has any other info please let me know
                      Does any one still have the pinouts for the output side? It seems to have disapered from allens site.
                      /Never mind, found it.
                      http://www.mp3fordescort.org/controller_pinouts.html
                      [ 01-09-2002: Message edited by: g60 ]
                      >\\MP3G60//<
                        Does anyone still have the data sheet on allen's controller?
                        I am kinda of confused, does the large nut on the board get 12volts or is that for ground? Also, what are all the other pins for, I want to see if i can interface my touchscreen thru it or not.
                        Thanks,
                        Bryan
                        :p "Which ones the any key?" Homer Simpson
                          another question: what does the connector that is labeled bl inverter do? is this an onboard inverter?? if so what is each pin for? thanks for your help.
                          Etrik
                          "if everything is under control, you're not going fast enough!"
                            it is for the backlight inverter.
                            i think the pins are.... in no particular order.
                            12v
                            5v
                            dimmer
                            ground
                            turn on
                            ~mike
                            edit....
                            then again i am going from memory, so i could be way off!!!
                            Single Member of the "1000 Post and No MP3 Car" Club
                            PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
                            2000 Cavalier Z24 [###-------] Only 30% Done ... Still
                              I think that it is just power for a backlight inverter and possible a brightness control it.
                              Bryan
