4x20 problems...ergh
  • 4x20 problems...ergh
    First off, I searched past messages for this problem to no avail..
    All right, turned out that hat 4x20 L2014 I got from was EIO.com was defective...which is very rare, according to them...but since the guys over at eio rock SO hard, they sent me a replacement for free.
    So I hooked it up using the schematics on their site, I even got the two rows of blocks (which means everything is hooked up right..woohoo!)...
    I used lcdprint.exe to check the lcd...lcdprint 378 shows:
    Standard Parallel Port detected
    BPP Mode supported
    LCD panel detected.
    "lcdprint 378 4 20 test.txt" which just kicks me back to the command prompt with no other comments on screen...(which I take to mean it worked.. or it thinks it worked..)
    But I get NO change on the solid bars of blocks...any thoughts?
    1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
    PC built into console
    worklog with pics: http://www.mp3car.com/vbulletin/showthread.php?t=46359
    Some of my music: http://www.myspace.com/markquestion
    Make sure the test.txt is next to the lcdprint.exe
    In holland we mean in the same "map" don't know in English
    must be something like this:
    C:\lcdprint.exe
    and for the text goes the same
    C:\test.txt
    they must be in the same Directory
    Peter3
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
      Also, only test it with a windows 9x machine... I don't know about WinMe though. Anything NT based shouldn't allow communication through the ports.
      -Miles
      Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
        This may be plainly obvious, but "test.txt" actually has to have text in it.
        I hope you already knew that...
        current projects
          Heh, thanks for the help, but its a Windows 98 machine, the test.txt does have text in it, and it is in the same directory.
          Any other ideas?
            change the parrallel port to ECP mode in the bios
              I recently replaced the matrix orbital 20X4 LCD with the same LCD you got from eio and I got it to work without problems, I think your bios setting is wrong too.. make sure it's ECP and the command of lcdprint should be:
              lcdprint 378 20 4 text.txt, and not 4 20 like you typed.
              04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
              Fast car, fast PC. ;)
              http://www.arcdesigns.net/carpc/
              My TL CarPC ver2
              FSR Flash Skin w/ moving weather maps
                Nope...I have it set for ECP..and the same thing happens if I switch the 20 and 4.
                I just can't figure it out because it *knows* the lcd is there and *thinks* it is sending output to it...but it's not. ergh.
                  I think you messed up your wiring man... other than that you might wanna try another computer.
                  My TL CarPC ver2
                    HALLELUJAH!!!!
                    Remember boys and girls, no matter how many times you check your wiring, check it again. Corrected *ONE* connection that was loose...and voila: The world is right again.
                    Stupid Radio Shack soldering iron. heh.
                      hehe, I'm glad you got it working.
                      I'll have you know that I built several circuits with my Radio Shack iron, and some of them actually almost work
                      -Miles
                        My radio shack soldering iron is a POS too...thought I might have just gotten a bad one, but I guess they are all crappy.
                          i bought one from dick smiths (same **** as radio shack really) and its terrible too. I went out and bought a butane solder iron after a week.
