How do you change the ratio in WinXP from 4:3 to 16:9???
  • How do you change the ratio in WinXP from 4:3 to 16:9???
    Does anyone know how to change the ratio in WinXP from 4:3 (LetterBox) to 16:9 (Widescreen)???
    ~$~h~i~z~a~n~k~
    Originally posted by synja:
    <STRONG>edit this key:
    HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO
    with regedit to make the resolution whatever you want, then reboot. In the article i read they changed the res to 848x480 so you can probably make it whatever you want. Microsoft doesn't officially support anything less than 800x600 and Windows XP complains both on log in (a bubble from the right edge of the task bar) and from the Start Menu, once opened.
    synja</STRONG>
    found this in another post, I guess you could try and manupulate it to be wide screen...but other then that I dont think you can.
      did this work?
