lcd brightness question
  • lcd brightness question
    i found an lcd that i can use butt he problem is that it is only 120cd bright.
    Do any of you know if its possible to change
    the backlight on an lcd? Doesn't this determine the brightness??
    -paul
    The backlight and inverter in combination determine the brightness, it is possible to change either or both. I'm not sure but the panel contrast ratio may also have some bearing on how bright it can be and still look good. If anyone knows for sure I would like to know that myself.
    http://jkllamps.com/
    http://www.ergpower.com/
    IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
    Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
