Help to find 12 volt input and ground on inverter from laptop.
  • Help to find 12 volt input and ground on inverter from laptop.
    If I use some kinda of 12 volt tester grounded to another source, can I find out which pin is the 12 volt input for the little inverter that drives my Sharp LQ94D021 TFT or do I have to ground it to the inverters ground?
    And can I fry my LCD or inverter by trying to find the + and -?
    The input on the inverter is a flat 5-7pin ribbon cable. This machine was a Dell Lattitude XP 4100cx.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
