Newbie Question for you LCD gods....
  • Newbie Question for you LCD gods....
    can i take a screen off a laptop, find a controller card, and make it work with my computer? if so...please tell me where to locate the controller cards at.
    thanks.
    take a look at earth lcd www.earthlcd.com
    thats all i know of for controller cards, but im sure there is someone here who knows of a few more sources.
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
      i was mainly wondering if it could actually be done. do you know?
        I can be done, but it's not cheap or easy. Start by finding out what make and model the LCD is, then start searching this site, Google, the forums at EIO, EarthLCD, etc. Find out what kind of graphics chipset the laptop used and then try looking for a controler using the sae chipset. For example, tonnes of laptops a few years ago used the Chips & Technologies 6550 chipset, and as a result there are lots of controller cards based on this chipset. If you find a controller card using the right chipset, find the specs on how to wire it to your LCD. You will also need to find what voltages are required to drive the backlight inverter, and a bunch of other stuff as well. All said, you'll most likely end up spending more than the cost of buying an analog VGA LCD or an LCD kit from EarthLCD. Best of luck, make sure you post here and share if you have any success.
          o, ok then...screw that. im not into wiring, soddering...none of that stuff. hehe.
          know any peeps with a cheap display for sale? im talkin CHEAP? i guess NTSC inputs? is that right? rca?
