Do i need backlight inverter for Sharp 6" LCD ?
  • Do i need backlight inverter for Sharp 6" LCD ?
    From the web search and data,
    i need 12V, 5V, -8V
    I need backlight inverter for Sharp 6" LCD even though i have 12V, right?
    I need to feed 12V to inverter and inverter will light up LCD.
    Is it correct?
    I want to make sure about this..
    Thank you very much
    Started
    <A HREF="http://www.mp3car.com/usersites/zp3/" TARGET=_blank>
    http://www.mp3car.com/usersites/zp3/</A>
    it depends on wheter your lcd has an inverter itself or not..
    I'm assuming for this brand/size/make that the ivertor for the backlight is already implemented in your LCD
    Is it correct?
    Part of...
    Depends on how much power/current the inverter needs.. but most likely this will be 12v
    Yes...
    your invertor will light up lcd by sending it's high voltage (~1000v) to the backlight-cathode (look out with this!).
    Can you post pictures of your LCD to make sure that it has an invertor.. I'm assuming it has one. but i always could be wrong...
    Greetz
    Raas
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
      LQ6RA01 from eio.com(and bought from jay) i think.. and have only bare LCD part
      I don't think i have inverter here
      Started
        OK. got the pictures of mine
        I don't think i have.. right?
        Please, let me know..
        so i can buy one tomorrow or not..
        (going to electronic shop tomorrow)
        Thank you.
        Started
          As far as i can see the lcd doesn't have an backlight-invertor
          The 2 wires coming out of the back which are connected to the cathode-backlights HAVE TO BE wired to an backlight-invertor..
          This is a special board that inverts the 12v up to ~1000v (almost no A's).
          You'll have to for a convertor that suits this display..
          Sorry , but i don't know where to gett them.. maybe flat-panel.com sells them..
          Maybe the other guys around here know where to get them.. Right .. Guys ????
          Greetzz and Succes solving your problem !
          Raas
