Can I use any of these?
  • Can I use any of these?
    Samsung LT104v3-101
    Sharp LM64P821
    Toshiba LTM09C011 B
    I have these just lying around. Can I use any of them with either Flat-Panel.com cards or another controller?
    Where can I find the cheapest controllers?
    Christian...
    Currently missing ATX DCDC power & LCD stuff =)
    I think the Sharp is dual scan - so you probably don't want to use it (dim screen, limited viewing angle and poor refresh speeds.)
    I believe the other two are tft and I imagine they should work with the Flat-panel.com controller. Best to send them an email to be sure.
    I've looked pretty extensively for "cheap" controllers as I suppose many others here have.
    Unless someone has seen something that I haven't ~$200 is about as low as they get .
    Gunnar
    A4.Avant.Work in Progress...
      I have a Samsung LT104v4-101 and that work great with an old ISA C&T65545 made by Dolch. I don't know if you can buy this controller anymore though?
      System under development (Just need to fit to car).
      10" DTSN flat screen with Microtouch touch overlay, 233Mhz Pentium MMX on a PICMG single slot proc card, 10 slot passive backplane (3 PCI 7 ISA), Custom Chassis, HARD Mounted HDD 6GB, Rand McNally GPS, SB Live 1024 Sound Card, Custom AC PSU, Jump it 300W Inverter, old ISA RS422/232/485 card, WinME:-(, WinAmp, AutoRoute 2001.
