Factory NAV Screen From 2005 Acura TL
  • Factory NAV Screen From 2005 Acura TL
    I have been searching like a madman for the best LCD screen. I want brightness and contrast like the super expensive screens used in some of the higher end OEM NAVs. Well, as luck would have it, I now have the screen from a 2005 TL. My question is, does anyone have any advice for me before I start hacking away at this thing? I just want to use it as a standard LCD monitor. I figure I'll have to strip it down to the bare LCD module and build my way back up. If anyone knows an easier way, I would love to hear it.
    2000 Acura Integra Type-R
    Progress = 99% ---> Check it out:
    http://www.matrixshark.com/carputer.htm
    Here is the backside:
      nice find!
      lots of plugs, do you have any of the harnesses?
      I'm betting if you can power it up, you can find a video input somewhere in all those harnesses.
      I would do 2 things. first open it up and try to figure out what manufacturer/model it is and get some specs and info. Second find a pinout or factory wiring diagram to see if you can just give it power and signal.
      I don't know that much about vga controllers and such, but maybe you can get one for that display and toss a touch screen kit on it... might be more of a project than its worth... I dont even know if its possible.
      have fun, dont fry it
        Back panel removed:
          1) It's already touchscreen, but who knows how proprietory that is.
          2) The goal is to hook up to it with a VGA or LVDS signal.
          3) If it fries along the way, so be it.
            Here is the face, removed from housing:
              It probably uses a RGBS signal...which I believe most OEM systems are...I know Lexus/Toyota and Nissan ones are.
                RGBS huh? Any Ideas what it takes to hook into that type of signal?
                Anyway, I am continuing the disassembly and I will post more pics along the way. It seems to have a pretty standard four wire touch panel:
                  great updates and pics... keep 'em coming!
                    Your wish is my command...
                    Touchpanel removed:
                      By the way this is Acura part# 39051-SEP-A43ZA and it retails around $2100.
                        wow... so how'd you get your hands on this?
                          If you want one I'd say get hooked up at the junkyard.
                            Next layer. I believe this is the touch screen controller that I am now removing:
                              Here's a peek under that metal housing. "Sumitomo Electric 5010-6980 HC712-1" appears on the board. A quick yahoo search on that part number yields no signifigant info.
