SHARP 6" LCD Display....
  • SHARP 6" LCD Display....
    I just recieved a sharp LQ6NC02 and cable connector kit. I was just wondering where on earth can I find a backlight inverter for this thing in Australia ?
    Is it possible to just use any source that outputs the recommended 330V @ 7A as specified in the data sheet?
    Thanks, and great forum!
    330V @ 7A
    I do hope that you mean 330V @ & 7 mA
    Is going to be a hell of power. 7*330v = 2310Watts ??? you will be able to power a small stadium with that..
    I think it isn't possible/recommended to uses just any source that outputs the suggested power..
    You should go the save way and get yourself a special for this display designed invertor.
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
      www.flat-panel.com - I buy all my lcd stuff from there.
      They are a paine to work with, and a bit pricey, but they know there stuff.
      Gizmo-
      Techonlogy on Wheels
      http://www.hjnetworks.com/car
