Where to get a TFT extension cord?
  • Where to get a TFT extension cord?
    Need to run my TFT a bit furthur away from the mainboard of my laptop. Uses a 31 pin connector (Hirose). Need a female and male connector and the wires in between. A custom job I would assume.
    In dash 800x600 touch screen man
    hi,
    It depends how far you want to put your LCD. Digital controlled LCDs can be up to appr. 50cm cable length away from the controller. Otherwise you have to use a LVDS sender and a receiver card or a graphics card with video out and a converter board for the LCD.
    Quite complicate, huh?
    The link for cables is http://www.quadrangleproducts.com/index.htm
    Good Luck
      i have a laptop with a sharp LM121SS1T509 passive matrix display. I want to put the display in the front of my car which would require an extention of 15'. Is this possible? or is it bound by the 50cm limitation?
