MPXF lcd config
  • MPXF lcd config
    Hello, I have a 20x4 LCD, does anyone know what line A values to insert in Line 2 and Line 3 in MPXFtsr.cfg to get a spectrum analyser with one base with each column going up the height of 2 lines not 2 separate spectrums on 2 separate lines. My player is set up I just want the type of spectrum that you can see with a Lorty or WinLCD plugin. Can anyone help please this is very frustrating?
    --MPXplay 1.476 & MPXF 1.44 Home Player--
    P166/32mg/20gigMaxtor/awe64/s3/cd/20x4 LCD/keypad
    Can't help ya there....
    I can't get my 16X2 LCD to work....
      Thanks anyway Skinny, after more messing about for another couple of hours, for anyone who runs into this problem -- I had assumed that the base line of the eq/spectrum LCD line 3 would translate to eq1 (thinking 1 is the start)this was incorrect.
      The values would be Line2 A value=%eq1 and line3 A value=%eq2 they are reversed to the order of the LCD lines, this will give you an eq that shows the strength of the frequency up to a maximum of 2 lines however I believe you can do this for 3 and 4 lines if you want to so that your whole lcd is a spectrum analyser.
      Skinny did you enable your printer port in the bios and check its setting against that in the MPXFLCD.cfg 888=port 378, just a stab in the dark.
