Lilliput menu button and remote doesn't work.
  • Lilliput menu button and remote doesn't work.
    I'm having bad luck with Lilliputs. The first one I while trying to mount it in the TMZ bezel. Clearly my fault. So, I order another one from Amazon. It actually comes from newtecpc.com.
    I decide the test it before cracking the case and voiding the warranty. I'm glad I did! The remote doesn't appear to work at all, and only the power, '<', and '>' buttons works on the front bezel. The red/green led changes correctly during standby and power on. The buttons are all blue backlit correctly, but the pc/av, the volume, and the menu buttons do nothing! Worse, the remote doesn't work (yes I installed the battery) I even checked it with the other remote which I know was working.
    Is there anything I can do to troubleshoot this? I'd really hoping for some sort of factory reset sequence and avoid sending the unit back. It's a 619GL-70NP/C/T, it has a 10pin connector and the serial number is 61981011B0189 if that helps.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
    bump.
    bump. If I don't get an answer soon, I'll just do an RMA.
    My worklog.
