Installing 6.4" NEC from flat-panel.com
  • Installing 6.4" NEC from flat-panel.com
    Ok, I just bought one of their "superkits" and i have a couple of questions about connections. First, I am assuming that the controller board needs 12v power correct? The plug cable they gave me has a stereo type connector , i was wondering if i can just cut this off and splice a ground and power directly to it. Also, in the loom for the vga cable there is a wire with a loose end and a little ring connector on it. I assume this is for a ground, where do I groudn it? to the little metal post on the controller board or to an external ground? thanks!
