volume indicator
  • volume indicator
    does anyone know of a way to kill the position sensor on the xenarc 7 inch non-motorized indash. Whenver it is leaning back I get this little window that says ))) 0 and the only way to get it to go away is to make the screen sit upright. My dash is slanted so the screen can't stay upright. I can't find anything in the settings, so i'm wondering if there is something I can just disconnect.
    "Dude, you could like watch porn and drive at the same time with that thing."
    bump, if anyone has any ideas i would be very grateful.
      bump
        am I the only one with a xenarc ts?
          a pic would probably help but the 0 you mention is it the one that comes up when u press the volume up and down if so maybe there is a faulty button press for volume down happening on your unit when it is in that position
          .______
          | '_ |__\___
          [(o)|___(o)] XB
          ._________
          | I__I I_I|_\__I
          [(o)______(o)]b VanPimpin'
          LostReceptions Apps D/L Here
          GPSGasoline- Rewriting
          CarPCNetwork
            yeah it is. If i tilt the screen in a certain direction that volume goes up. When the problem i'm talking about happens the volume goes to 0, but it doesn't disappear it stays on the screen. I guess the next question is if I don't use the speakers that are built into the screen would disconnecting the buttons solve my problem?
              Does sound like something is "pushing" the volume button (maybe a trapped cable or something) and it's as if you were holding down the volume-down button (thus the readout stays on screen). Check to see if something is becomming trapped
              VIA M10000
              512Mb RAM
              30Gb 2.5" HDD
              Bluetooth, 802.11g, GPS
              Silverstone USB DAC
              Consult (ODB)
              CarTFT K500
              Carnetix P1290
              NLited XP with Road Runner and MapMonkey
