LCD not working (this is different then the normal)
  • LCD not working (this is different then the normal)
    I got a 4x40 lcd,
    The first time I hooked it up, only stuff would display on the first two lines,
    Then I unsoldered it and hooked it up again, and did it wrong, and ended up applying +5volts to the wrong line (not good, I know)
    So I redid it, and it still boots and displays boxes on the first and 3rd lines, but I can't get anything to display, even just using lcdprint in dos.
    Any help would be great.
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    What schematic did you use to wire it up?
    Peter3
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
      this one
        Well the schematic is oke.
        have you tried to adjust the backlight and the contrast. Because mine is just showing bloks on the 1e and 3e line when i set the contrast to dark.
        peter3
          Istrunk: you probably burned out a controller (or two). I have done that same thing, and while the backlight works fine....controllers won't
          Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
            Does that mean I blew the whole lcd?
            If so, that really blows, cause I really wanted a 4x40 lcd, escpecially since this one was free ;-)
              lstrunk did you ever get that LCD working?
