How do I get my PC to be viewable on a TV....
  • How do I get my PC to be viewable on a TV....
    I've been perusing the forum for sometime now. I have recently purchased an adaptor that takes my VGA out and converts it into an RCA connection. I tried to see if it works with my tv at home and it doesn't. I can vaguely make out that it does show my background and stuff but the screen rolls around beyond acceptable viewing.
    Any ideas? Please be gentile!
    [ 08-23-2001: Message edited by: SomeoneLost ]
    Jason
    Daily Interlude
    http://www.teaminterlude.com
    check your "vertical hold" setting on your TV and you converter (if it has one)
      Originally posted by bgoodman:
      <STRONG>check your "vertical hold" setting on your TV and you converter (if it has one)</STRONG>
      The convertor is nothing more than a cable adaptor. No box. I don't see any verticle hold on it. When I get to work tomorrow, I'll give a link to the cable adaptor I am using.
      Jason
      Daily Interlude
        Found one surfing on Ebay.
        http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1267123181
        Ever seen this adapter? How can I make it work (if I can)
        Jason
        Daily Interlude
          sounds like he is trying to run a tv on the vga sig. but it has the wrong virt/horz freq. to do that you need to CONVERT not just adapt with a cable!
            Originally posted by SomeoneLost:
            <STRONG>Found one surfing on Ebay.
            Ever seen this adapter? How can I make it work (if I can)</STRONG>
            That adapter will not work. It is made for laptops that have a tvout on the regular VGA pinout.
              <STRONG>
              That adapter will not work. It is made for laptops that have a tvout on the regular VGA pinout.</STRONG>
              Figured! That sucks! How about the TVAtor made by Antec? I just purchased one for $10 bucks off ebay but can't really find much info on it. Here's the link(s) to what I got. http://cgi.ebay.com/aw-cgi/eBayISAPI...6&ed=998622697
              There is also another auction with the same exact product: http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1266107202
              Ever heard of it?
              Jason
              Daily Interlude
                <STRONG>
                </STRONG>
                That will work just fine.
                www.arbybean.com
