Difference Between EL and LED backlights?
  • Difference Between EL and LED backlights?
    anyone know what the difference between EL and LED backlights is on character displays? I just got a 2x24 from optrex and I didn't think it had a backlight because it was so thin..then I found out that it's an EL backlight. Are these better? Anyone know how they look from experience? Just curious... Thanks.
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
    I think EL backlights you need an inverter for.. where as regular character LED backlights just run off +5VDC.
    Could be wrong...
    95 Honda Civic DX Coupe - In Progress
    mp3civic site
      EL backlights are thinner, use less power, and light more evenly. They also require an inverter and are more expensive, though
      www.arbybean.com
        Any idea where I can find an inverter for one? I just got a really nice sample for free, but I am inverterless. EIO and EarthLCD don't seem to have anything of the type. Thanks for the clarifications.
          Also, does anybody know about the backlight brightness adjustment with EL's? do they use a 100 ohm pot just like the LED's?
            The EL brightness is usually controlled through voltage. The higher the voltage, the brighter the backlight and vice versa.
              Try Digikey.
              mp3civic site
