How do I hook up an inverter?
  • How do I hook up an inverter?
    Are there data sheets for these things - is it anything special. I can't come up with anything. I've seen several data sheets (not for my type) that show V+, V-, Control, NC. What do these match up to if I just want to hook it to a 12V DC source? Any direction would be helpful. Thanks.
    I have a JRC NJD-4280 UA0392p01
    It has 7 wires on its input - how in the world do I figure out which is which to power this up?
      Beats me. V+ and V-? Most inverters only have two inputs. Positive and negative.
      Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
      Car: 1993 Nissan Maxima, Black Emerald
        Most should have at least 4 pins. My sharp inverter was a 5 pin input.
        1) +12VDC
        2) ground
        3) N/C
        4) Control
        5) Control
        So 4 and 5 I put a pot on to adjust the voltage.. and then obviously 2 pin-outs for the AC voltage.
        I'm not sure why there would be 7 pins. Are they all used?
        95 Honda Civic DX Coupe - In Progress
        mp3civic site
          I can identify two for the pot, that leaves 5. They are all used as well. By the way, this may be dumb, but what is N/C?
            I think it means not connected or not used.
            04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
            Fast car, fast PC. ;)
            http://www.arcdesigns.net/carpc/
            My TL CarPC ver2
            FSR Flash Skin w/ moving weather maps
              http://www.laptopking.com/inverterlist.asp
              These guys sell that inverter and service laptops, maybe if you drop them an email they'll send you some documentation or at least tell you the pinout.
                Thanks - I have actually begged every person who retails this piece I could find - no one could help me.
