Need some help on 2014 and 4034
  • Need some help on 2014 and 4034
    I have bought on eio.com the seiko 2014 and the 4034.
    Wired them up and run lcdprint , they worked.
    But when i use the 2014(4x20) with the plugin from Markus Zehnderit works great whit the 4034(4x40) it display nothing (on screen it looks ok).
    Using a diverend plugin (mark Lynch) the 2014 doesn't work but the 4034 works great .
    So i'm confused/going mad.
    Where do i go wrong?
    this is the sys i'm using to work things out:
    P II 350 mmx 128Mb of ram 20.Gb HDD
    Os win98 mobo MSI-4017(not shure about this number)
    So I need some help from you outthere to fix the problem
    Peter 3
    [email protected]
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
    Check your wiring. By the way when did you buy the L4034. They are sold out now. I was told that they could get me one but it has been almost a week and nothing has arived. The last one I bought got here in 2 days. They have taken my money. I had trouble with the connections to the pins when I hooked up my L4034.
      Fbwr75215 If checked the wiring and double check it can't find anything wrong They bouth work with lcdprint.So the wiring must be ok.
      Only 1 is working ok with Marku zehnder's plugin (20x4).
      And the other only with the plugin from Lynch.
      I read that Mark Raas has used a ide cable to conect the lcd.
      He cut it on lenght and shaved a bit off from the bottum till you see the beginning of the conectors(pins) And then secur it with some Hotmelt .
      Peter3
        It seems that when i only use row 1 & 2 it works ok.
        But when i use 1,2&3 line 3 overwrites line 1
        And when i use 1,2,3& line 4 line 3&4 are overwriting lines 1&2.
        Does anybody knows where i go wrong.
        I used the schematics from Nathan Stuart for the seiko LM4034 On my L4034.
        Peter3
          Another update
          I was wrong in the last post
          line 3 is overwriting line 2
          Line 4 is overwriting line 1
          I know it's wired up ok because i cheked it whit Cobra I and it works great.
          So i cheked 3 plugin's and 1 isn't working and that is the one i want to use see above.
          So HELP HELP HELP am i goeing Nuts ore is it just the plugin witch isn't working.
          Has anybody have the same problems whit this plugin ? If you have let me know,If not let me know it as well. Thanks peter3
            Well i know what wend wrong.
            So if anyone has the same problem here is the solution:
            Goto configuration -> Display -> Configure -> settings -> and set the splitscreen on.
            Now the display is working fine
            Peter3
              Hey Peter,
              Thanks for the info on the split screen..
              (I noticed that too, that lines 4&3 where overwritign 1&2 .. didn't know what it was.. but the lcd worked with lcd-print, so I assumed it was working the way it should be...
              However.. I haven't jumped into it then. 'cause I was not satisfied with the cable I had made.. (was just a test cable to see if the display worked).
              Now I'm making my new cable.. Control & lcd-connections all in one cable . )
              Greetz
              Raas - The Netherlands
              ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
              GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
                k.
                guys.. I am new to wirind boards.. but I have a similar display.. the data international version.
                I know nothing about wiring.. I saw on EIO website, connectors to hookup to the board.. I can't imagine how I can wire something into those little holes withou some sort of pins.. or connectors..
                I see ya'll made stuff.. can you give me a little info on how you did that.. or where I could be connectors?
                Also, I will be getting power for my display through my USB port.. has anyone done this before?
                Thanks,
                Christopher Vigil
                Isuzu Rodeo[list=a][*]Toshiba Tecra 8000[*]Docking Station[*]Pioneer Controller cable (modified)[*]maX10 mouse remote (x10)[*]Data International 4x40 LCD[*]laptop power converter[*]Mobile Bay w/80gig harddrive[/list=a]
                http://www.vigils.net/users/christopher
                  georgia tech
                  Take a look on the exsample pages and visite some of those site's and see how these boy's and girls? did this.
                  If you still can't find some info mail me
                  Peter3
                    you're right about getting this much cables in so many small holes..
                    When I received my display from eio there was a short note that the display would come from a batch which had a header-connector.. ( so it has pins )
                    the only thing I did is placing a (shaved-down from the bottom) IDE-connector onto it.. and this works..
                    I don't know about getting these wires in these holes..
                    Maybe Arby has some trick to that.. ? Arby ?
                    Greetz
