72 solder joints and it actually works
  • 72 solder joints and it actually works
    Click image for larger version
    it only took me a few weeks, 3 irons, and 2 packages of heat-shrink tubing, but now i can mount the display 3 feet from the controller (and that's not my hand, it's my little brother's)
    I'mmmmmm a n00b.... feel free to make fun
    that's hot! Nice man
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
      Very impressive!
        very nice ! like gbh said... impressive.. but where dit you get those blue cables from they look like the've been stored underground lol
        my destinator map resource down permanently
          Cat5 cable. Available at any decent computer or electronics store.
          How about the Wiki?
            damnnn... i would not have the patience for that! lol. nice job
            My Site: http://www.reinerweb.us
            My Car : http://members.cardomain.com/reiner15
            Car Computer Alias - TekPC
            Current Progress - - Brainstorming
              actually those are shielded Cat5, idk if it helped any, but in addition to being braided, it's got some metal shielding around the whole thing. And the reason the cable looks ****ty is because the spool of it was sitting outside for a while.
                What is the model number of that panel?
                Where did you get the controller for it?
                  Nice.. the LCD panel itself is probably LVDS.
                  IIRC, you can go up to about 3 feet with regular unshielded twisted wire..
                  With shielded wire, you should be able to go farther, 6-9 feet or more.
                  Of course, that's assuming the LCD panel is LVDS.. I can't tell from the picture.
                    huh? I have 6 LVDS panels up and running right now with UTP cable, and one of them is 16ft long. (cable that is, not the lcd panel)
                      I forget what the cable length limits are for LVDS, but they can be pretty far.. 16 feet is pretty cool.
                        From the information I have gathered over the years, LVDS can transmit 15 meters without an amp. and can run 60+ meters with an inline amp attached to boost signal strength. In my testing, I have found UTP to actually work better, so long as the cable is 100 ohm resistance. less or more resistance provides for an unstable signal. using Cat5 can be a real pain in the arse if your application requires tight bends, etc. The vast majority of Cat5 is solid copper wire, not stranded, which obviously is not very flexable.
                          hey dude,
                          that looks obsolutely sweet
                          what's panel are you using?
                          kao
                          CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
                            Originally posted by ptk
                            hey dude,
                            kao
                            NEC NL8060BC31-28D. 350nits bright (stock, I boost some to 760nits) 600:1 cr (high for a 12.1" panel), wide viewing angle, and the panels are hard coated, anti-glare.
                              So why is this an advantage or why was this done?
