Making a really short Lilliput VGA/USB cable... need tips
  • Making a really short Lilliput VGA/USB cable... need tips
    Hi. I managed to get the whole carputer in a gutted donor radio, so I was left with several extra feet of unnecessary Lilli cable. So, I thought, I'll just clip the cable and solder everything back together. Well my first try didn't work, so I guess I'm just lousy at soldering.
    Before I cut into it for a do-over, would it be better just to do away with the din connection and go to a one piece cable? Anything to look out for?
    Also, do I really need the choke on the VGA cable? If not, I can lose even more cable length.
    1998 Volvo V70 R AWD
    2.3L Turbo @ 17psi, 20% Tint
    SP-13000, 7" Lilli, Opus 120, 120GB SATA, Holux GR-213, Headrest LCDs
    Use meters to verify match wires. If you use color code to match wires, you will be screw. Worst case, you fried the screen.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
