controller for NEC NL6448BC33-59 10.4" with ELO touch screen
  • controller for NEC NL6448BC33-59 10.4" with ELO touch screen
    Hi everybody,
    I have couple of NEC 10.4" 640x480 LCD with touchscreen as above mentioned. There is no controller with either LCD or TC. Can someone recommend a cheap controller ? My video card has VDI-D output so can I make a customized wire directly from LCD FDP 20pin connector to DVI-D connector ?
    Thx
    007
    My install in Toyota Tacoma
    http://www.mp3car.com/vbulletin/showthread.php?t=91579
    the lcd panels you reference have 31 pin connectors, not 20 pin.
    btw, those are nice panels. 600:1 contrast, 450 nits bright. decent viewing angle. A little slow on the response time (33ms) but still a good panel for all around use. Too bad they are 640x480 native, but in a car that is perfect w/a 10.4" panel. (IMO)
    what model number are the ELO panels?
    what inputs do you want on the lcd controller? (vga only, or vga + rca, s-video)
      Thanks for the clarification.
      The touch screen panel says this "362740-6816 EloTouch systems TF040"
      It has 5 wires (4 pink 1 gray)
      For LCD I can live with either VGA or DVI input.
      Can I by pass the LCD controller if I go for DVI ?
        Are there any other numbers on the touch panel?
        answer to question: No. The lcd panels you have require the use of a controller.
          Nah, 800*600 minimum for text on maps etc.
          buttons can be designed to be same size under all resolutions etc but better res=better pics/fonts etc
          I just tried to go back to 640*480, I cried. (and my tvtuner wasnt happy)
          Lez, more widely known as flez1966
            Those are the only numbers I can see on the touch panel. will it work ?
            I have a small circuit board that says 314041 ELO Touch V1.0, may this is the serial TC controller ?
            What LCD controller will work with my LCD ?
              OK this is getting interesting.
              I found a development board that takes the 30pin LCD signals and using Thine 0409TI03 chip converts to LVDS. The board has DFP out. Then a cable takes this DFP out to 30 pin DVI (may be DVI-I). The board also has 12V in and out for inverter.
              The problem is how can I connect this 30 Pin DVI (digital + analog) to my pc which has 24 pin DVI-D (digital only) ??
                send pictures, please. controller and touch panel. I cannot locate any info. on them.
                  huh?
                  links please.
                    true, but for us blind people, 640 is just fine.
                    in a perfect world, I would have a 1600x1200 panel in my truck.
                      OK When I go home, I will post some pics.
                        don't you have your outs and ins turned around?
                        the controller puts out 30 pin TTL?
                            OK here are the pics.
                            TC and controller. Need advice on cabel, power input.
                              motorcity,
                              do you have any controller for my LCD ? If not, what models should I look for on ebay ?
                              Thx
