Double Din Touchscreen
  • Double Din Touchscreen
    Will this work? Which ports are needed to connect to the computer?
    http://cgi.ebay.com/207-2-Din-6-5-To...QQcmdZViewItem
    no almost all screens with a tv tuner are ntsc or pal thus not VGA u need one with vga input
    please search for screens with vga inputs
    been covered alot here
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
      I almost got one of these, You need a VGA monitor, and that IS NOT one your picture will be enormously bad!
        "- Radar input"
        that's an input I'd never seen before..
        Causa latet vis est notissima
        VIA SP13000
        1GB DDR400
        Slimline Slot-load DVD-RW
        60GB 2.5 Inch SATA 5400RPM
        Dual Active PCI riser
        PCI TV/FM card
        Logisys FP800
        Thermaltake VFD Media Lab
        M1-ATX
          I just purchased the LM6508 on ebay. For computer use, it really wouldn't work, because it's not vga, also the touch screen is specific to the software that the unit uses, it's not a touchscreen you could use with your computer. The picture quality isn't that great. With the contrast and brightness all the way down, it's still too bright and harsh. The main reason I bought it was for radio use, and a cleaner looking install. I have the video out to my xenarc screen, and the picture quality is pretty good. Only problem I have is an extremely high pitched whine coming from the unit itself. Sometimes it goes away after about 20 minutes. I'm not sure how to fix that problem.
          And the rader input is a "backing radar". I think it's one of those devices that let you now how close an object is behind you.
