What happened to the LCD backlight upgrade thread?
  • What happened to the LCD backlight upgrade thread?
    Sorry if I missed it but the old thread died quite a while ago and a new thread was referred to but Ive never been able to find it... Any help appreciated.
    I was waiting for new backlight upgrade too but never arrived. So I started to try some SMD LED solutions.
    Some Pics :
    Could see the rest here :
    Lilliput Backlight Upgrade
    But haven't much more time to continue.
    New prototype : 2DIN AUDI OEM-LIKE CARPC based on SYMPHONY II
    Motorized InDash Screen, Core 2 Duo 2.2Ghz, SSD
    Home Made In-Dash 7" Lilliput V1
    Home Made In-Dash 7" Lilliput V2 = LM-Lilliput Prototype
    First project in Peugeot 306
      have the same Problem, searched a new thread, but didn't finde on
        Well i know Jcdillin is working on two projects, The whole upgrade including the tubes is on hold because of sourcing problems.
        The inverter upgrade however is being activly worked on. The is what he is using right now and it is sunlight readable. JCDillin has been sourcing and testing different inverters that support PWM. The thought is to use two sources to change the brightness, 1 button (similar to the lilliput except have more bightness levels) or an photocell that will read the brightness and adjust automatically.
        Keep an eye out for a thread detailing this soon.
        All the credit goes to JCDillin on this one
          An invertor upgrade will kill the backlight pretty quickly. A ccfl has a half life in terms of brightness. Upgrading the invertor lets you drive it brighter but it also reduce the half life. Since you can realistically expect 2-3 years of life if you are lucky (I got 9 months from my lilliput before the brightness had dropped very noticably), driving it harder with a more powerful invertor means you reduce that - usually by quite a bit. I really don't want to have a solution that involves replacing my ccfls every 6 months.
            What's the difference, the lilli's don't usually last longer than that anyway
              thats right me 5 lilli's last about 4 weeks (each)
              my xenarc now runs since 8 month without any error or fault.
              and there I won't risk to burn my ccfl
                I ran mine for 10 months without any reduction in brightnes. So I really dont see how the stock inverter/lamp combos are getting dimmer after just 9 months, maybe faulty parts or crappy tubes. But I have ran my overdriven tube now for over 10 months and it's still just as bright as when I first started with it. So even if for some reason it decides to get dim here in the next few months i'll just slap another LCD in and go to town. Even if I replace it every year thats only a $100 a year for a LCD panel ($100 is a rough estimate, most I have been able to get for less than $50). So after 5 years i'll end up costing about the same as the LED backlights, just without the heat and all at once expense.
                肚子笑痛了
                S60 Install
                  Well, since my CCFL is already toast. I may as well experiment - how did you upgrade your invertor?
                  It's not just the frequent upgrades - it's the hassle of having to take apart the dash in order to replace bits of the monitor and the risk of breaking the monitor each time and being without your screen until you get a replacement.
                    i'll get you the mouser part number that I used
                    肚子笑痛了
                    S60 Install
