Lilliput works at home but not in car
  • Lilliput works at home but not in car
    hello,
    my lilliput turns ON when i connect it to home power but when i connect it in car i cant get power ON,it works fine in car before few days ago,i checked with a small lamp to see if the power is runing thru the +/- cables and its ok,the lamp is turning ON.
    i use the lighter cable after cutting it in the end wheres the plug connects to the lighter in car and get 12v from the +/- that runs my radio in car before to run my lilliput in car. please...any ideas??
    tnx
    Originally posted by zx16v
    hello,
    tnx
    Did it work before? What changed? Anything?
    What happens when it is connected? Anything?
    Are you sure that you have the wires connected to power correctly, + to +, and - to -? A light will work no matter which way the + and - are connected, but the screen will not.
    Michael
      yes,it worked before,now when i connect it in car nothing is happan,no red led to indicate that i have power ,also try to turn it ON and nothing,at home its working fine.when i cheaked if i have power in car i use LED that have + and - the LED was turn ON. any ideas...?
      tnx
        here you can see it working in my car http://www.cardomain.com/ride/673284
          Check to see if you blew a fuse on the Lilliput.
          Want to:
            if the fuse is blew so the lilliput don't work at home also,no? ,also im thinking about that i moved the car battery to the back of the car because of the air filter i had to move up ,but i got very good cables that running from the front of the car to the back,every thing is working fine like the car battery was in the front execpt the lilliput,maybe this can be the problem..?
            tnx
