window start up but won't display window
  • window start up but won't display window
    i am in a big headached, tried searching but no results,
    anyway, my liliput started window i can see the boot window on screen but when it goes into window, my liliput went into blank flickering ...
    pls help , i'm running on m10000
    Progress Bar: [//////////]100%
    Have M10000, 40gb 2.5"hdd, i guidance, wireless,slim slot drive, delorme gps, roadrunner, liliput touchscreen, opus150w ...
    all fabrication done...
    pls delete
    problem solved, mod pls delete this thread
      It would be infinitely more useful for you to describe the nature of your problem as well as the solution so that future generations can benefit from it by using the search tool.
      How about the Wiki?
        similar problem
        I had a problem similar to yours. turned out my vga drivers we bad. I have an onboard vga card and my PC is like Frankenstien so I had no idea what drivers to install. I searched online and found out how to read motherboard manufacturer codes. I looked on the motherboard, found out what kind it was, then went to the appropriate website. I still didn't know what drivers to install so I installed the live update software for my mother board. Ran the program and the drivers were selected and download for me. Haven't had the flickering problem since.
          my settings for my vga card is wrong, reset it, play with it , the resolutions and refresh rate, problem solved.
