Lilliput 8" Touchscreen broken
  • Lilliput 8" Touchscreen broken
    So I've got my LCD bondo'd into the dash, the vga works, it powers up no problem (well there were problems but I kept reseating the cables till that went away) but the touchscreen does not respond. Windows detects the controller when I plug it in, but touching the screen has no effect. I have a second touchscreen lcd, its an NEC ELO device, it works no problem, uses a different driver though.
    Is anyone else running dual-touchscreens? Is this a common problem? Or did I f**k my touchscreen at some point?
    -w
    P4MST-890 775 MicroATX Pentium Dual Core E2140 , 80GB 2.5", OPUS 320W, MS GPS, SB EXTREMEGAMER PCI, 8" LILLIPUT TS, 15" NEC TS, SIRIUS USB PC INTERFACE, STREETDECK, KICKER ZX850.4, KICKER 2500.1, 2xKICKER SS65.2, 2xKICKER 10"COMPVX
    I had actually searched for an answer to my problem before I posted, didn't find anything, but once I had posted I saw similar threads to mine. It also occurs to me that this is a new windows installation, and I don't think I installed the touchscreen drivers. So I'm gonna try that. Otherwise it's looking like a replacement overlay.
      Not the drivers, installed the newest from the site as per the instructions, so unless this is a common problem for dual touchscreen setups, I think my overlay is broken.
      Consensus?
      -w
        Where did you get the drivers from? I recommend you get them from here if you have not.
        Install the drivers, and run the touchkit program to calibrate it.
        WORKLOG
        Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
        Webpage
