double indash (2x Lilliput 7" motorized) in Golf IV
  • double indash (2x Lilliput 7" motorized) in Golf IV
    Hi there!
    This is my first post here, although I've been reading mp3car.com for long time ... I usually participate in a Spanish forum www.solocarputer.com and I just wanted to say hello to everyone (cool forum and super-useful information, guys!) and to present my little experiment here.
    When I first thought about installing a carpc, I didn't like the idea of having a little (7" or 8") monitor and tried to install a normal desktop TFT, but failed miserably; there was no room to place such a thing, it would be _very_ notorious from the outside, and it wouldn't even look good from inside.
    The solution proposed was very simple: multiply
    At first it was intended to be used as a simple multi-monitor carpc; but now I'm into using it to be able to run both Linux and Windoze at the same time, using a spare laptop.
    More info, pics, and some videos in
    http://www.solocarputer.com/phpbb2/viewtopic.php?t=4991
    and
    http://www.solocarputer.com/phpbb2/viewtopic.php?t=1408
    ( Again, thanks to everyone for your contribution to the "carpc science" )
    Cheers!
    My project: double indash, Golf IV
    http://www.mp3car.com/vbulletin/showthread.php?p=841754
    That's wacky, but cool....
    How about the Wiki?
      Loco!
      Nice one, but a little low for TS, no?
      List of front-ends/usefull apps
      XTroniC | XTroniC Direct
        Dat's whack, yo!
        So far:
        M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
          Ho, I have already thought about that , but you did it before...
          can't wait to see the final instal and see it working.
          New prototype : 2DIN AUDI OEM-LIKE CARPC based on SYMPHONY II
          Motorized InDash Screen, Core 2 Duo 2.2Ghz, SSD
          Home Made In-Dash 7" Lilliput V1
          Home Made In-Dash 7" Lilliput V2 = LM-Lilliput Prototype
          First project in Peugeot 306
            when shifting, how do you not hit the bottom screen with your knuckles?
              get a pickup truck shifter. And if that isn't long enough, get one of the shifter from a semi.
              Y2K Accord Dell GX150
              EmoRebellion is a SCAMMER
                longer? you want a shorter shifter so that it goes under the lcd. A longer one will just make you hit it sooner but at a higher height
                Alex
                90 300zx twinturbo conversion
                Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
                  Even with the inverted screen a little bit angled, I have no problems to change gears. I have to be careful when opening and closing it, but that's ok for me
                    *****/5 stars for innovation. Great Job!
                    Sound Stage
                    Eclipse|MTX|Infinity
                      Thank you all for the nice comments.
                      I will post about the doble carpc Windows/Linux A.S.A. my college exams are over.
                        Hey, I saw this idea before, but you're the first to do it that I've seen! Really cool! Now someone needs to outdo you and have FOUR! HAHAHA...
                        Good luck on your exams.
                        Cache Builder for GE is here!
                        My Sonata's Gallery.
                          Not a chance! 4? hahahah
                          That _is_ nasty!
                            very innovative, but I have to ask why?
                            I drive a MKIV GTi as well, and I can't even imagine having another screen down there, let alone going through the process to close the bottom screen....
                            think you could get a video of the whole process? (opening and closing of both screens)
                            Jan Bennett
                              The original idea was to simultaneously run different programs such as gps nav and the multimedia player, but then I realized it could be even more useful to have two computers.
                              There are some videos available -opening and closing- , just follow the links a few posts up
