lilliput 619gl crazy colors!
  • lilliput 619gl crazy colors!
    for some reason my liliput 619gl screen is showing some really crazy colors. like blues, fuscias, purples instead of the normal picture
    does anyone have any ideas of a way to repair this?
    Loose/busted cable maybe?
    Tidder
    Try RevFE
    I Wish I could ban people
      i have reconnected the harness many times and it is not doing anything
      i've also tried removing power
      here is an example of the type of colors everything is:
        Hmm... probably loose ribbon inside. I don't know much about this screens, so I hope somebody else jumps in here to help. Have you searched for your particular problem to see if anybody else had the same thing?
        Tidder
        Try RevFE
          Check this out.
          http://www.mp3car.com/vbulletin/show...iput+619+color
          Tidder
          Try RevFE
            yeah i saw that earlier... thats why i posted
            i think im in his same boat about exchanging it... and dww is out of stock on the cables
            i tried to reset it a couple times and still no dice.. this is very disappointing
              another thing is that the VIDEO 1 green text displays fine... however the menu back ground is all purple
              it does the same thing w/ vga input so i have concluded it is not the wireharness for rca...
              so maybe i do need to replace 40pin cable
                Problem Fixed! It was a nightmare messing w/ that ribbon cable but i finally got it to work right and while i had it apart i removed the vga stuff, touchscreen (not needed for xbox), and put a 1ft extension cable on the IR receiver.
                  my screen turns a shade of green when it get too hot
                  My Nissan 200SX @ Silverstone
                  NOW SADLY WRITTEN OFF!
                  My Car's spec list + pics
                  Stealth CarPC fab'ing...
                    Cool, I figured it was gonna be that little ribbon, seems to be the biggest prob with those screens.
                    Tidder
                    Try RevFE
