experts required
  • experts required
    I have one Hitachi LCD like the ones used in Lilliputs or Gain. And one Toshiba lcd. I want to use the toshiba lcd with hitachi parts(back light, controller...)
    The actual cable coming from LCD panel is different, (http://www.diyprojectorcompany.com/i..._016_small.jpg) and i cant hook it up to the hitachi part. Is there anything i can do about it?
    Different physically, or different electrically?
    You need datasheets for both panels to see if they are similar, then if they are, a simple rewire may work.
    If the use different signalling systems (LVDS versus TTL for example), you have some work to do, that more than likely will get expensive.
      they are different physically. i have my stock toshiba screen, i want to convert it to vga.
        where can i get datasheets?
          Have you searched at all for them?
            what is needed to convert a screen to vga using the hitachi parts from lilliput?
