From Lilliput to RNS-E (AUDI A6 1999)
  • From Lilliput to RNS-E (AUDI A6 1999)
    For a while now i have my system running using a Lilli.
    I wanted to give a factory look to my A6 Carputer. I had two options.
    1. Get a double din cage and integrate the Lilli in the dash, then relocate the head unit in the glove box.
    2. Get an Audi RNS-E sat nav.
    Option 2 is a clean process, so I gave it a go. I will have to find a new input device, since the touch kit will be out of the picture.
    The next step? Purchase the parts required.
    1. RNS-E Sat nav. Found one on E-Bay in very good condition.
    2. CAN BUS emulator (This is required for Audi A6 pre 2000 models). The best place to purchase it from http://www.kufatec.de/
    3. Double din cage and climate control face. The colour of the RNS-E is soul black. I bought them from http://www.partsdealer.de/ , used but in excellent condition.
    4. Antenna adapter and removal tools which are very easy to find.
    So after two months waiting for parts, the migration process begun.
    - CarPC: Lilliput 7" Touchscreen, VIA EPIA M10K, 512 MB's of RAM, 40 GB's HDD
    -AUDI RNS-E
    Migration
    Start point:
    Remove the upper cover:
    Remove the frame around the head unit and AC:
    Insert the head unit removel tools:
    Pool off:
    -AUDI RNS-E
      Migration
      Heat unit removed:
      AC removed:
      Ash tray removed:
      Shift stick cover removed:
      Carputer in glovebox, needs to be taken out:
      -AUDI RNS-E
        Migration
        Carputer Removed:
        Panel below steering wheel removed:
        Center console removed. At last, the single din cage can be removed:
        The double din cage installed:
        The RNS-E and AC installed.
        -AUDI RNS-E
          damn homie. how much did dat oem sat nav cost? i know it was definitely hella clean. yeah it sucks cos the 1998-2000 A6s have like single-1.5 din and the 01-04 got double. Im getting prolly a 1999. If im lucky maybe a 2001 4.2L. So now, can u post screens of ur oem screen displaying your carputer?
          [HL]My Worklog (~75% complete, but fully functional)[/HL]:
          http://www.mp3car.com/vbulletin/work...t-install.html
            If you can get the 2001, that one has CAN and the RNS-E is much easier to retrofit.
              Hey, i have an A6 1998 with 1 din and i am planing to do the same nice job like your's. Please tell me this: do i have to buy another klima or i can use mine?? thank's a lot
                Hello
                I do the same conversion as your but at the moment I struggling a little bit. I cannot put the gear cover plate back in the place.
                Do you know the way to put it back and How you do that?
                Do I need to trim or change this plate or outside center console unit?
                In the conversion I change
                1. from 1din to 2 din bracket
                2. Climate control unit
                3. Ashtray
                Do I need anything else in this conversion.
                Thank you
                  Hi Xplorer
                  I did the same conversion as your. However, I cannot put the gear cover plate back into place. Do you have any suggestion how can I put the plate?
                  In the conversion i change
                  1. 1din to 2din cage
                  2 2din type climate control
                  3. 2din type ashtray.
                  there is just only a small clearance between ashtray and lower plate.
                  Do I need anything else or any part I missing for this conversion?
                  thank you
                    audi a6 navi
                    thanks very much for the post, I've followed the steps and installed my dvd navi now, it's just a similar nav as the original one http://www.cars-electronics.com/audi...een_p1309.html I will post some pictures later.
