Kenwood PC Screen
  • Kenwood PC Screen
    I have been following a couple of old threads about having a Car PC running into a Kenwood Head Unit - Using the RGB Navigation input.
    Is there a plug you can get to go straight into a PC or do you need to solder something up???
    The unit is a DDX-6039.
    You want to run the video of the PC into... Another PC?
    If I understand correctly, you want to know if there's an adapter cable to allow connecting the Kenwood unit directly to a PC....
    Yes. You can use a video device with TV-out or a scan converter to get composite video signal to the Kenwood unit (assuming it has composite in).
    You will not, however, have use of the touchscreen for the PC. That's why the guy hacked the unit, so he could use that functionality on the PC.
    How about the Wiki?
      Sorry - I want to have a the video output of a PC go into the Kenwood using the screen as the display via the RGB navigation connection.
      Ive seen it done but cant find any wiring diagrams.
