I only get 640 x 480...no 800 x 600
  • I only get 640 x 480...no 800 x 600
    I have the new Lilliput touchscreen with transflective and I installed the newested drivers but I only get 640 x 480. Why is that?
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    Some more information would be very helpful.
    Motherboard
    Videocard/chipset
    operating system
    Did you check the FAQ's?
    Yeah google!
      Make sure you install your video drivers too.
      Images will display, but it is probably suck at 640x480 16bit too. Easy check is to see if you are able to suspend the pc. those rely on the videodrivers too.
      1.9in x 2.9in -- 47mm x 73mm
        I have the EPIA CN 13000
        The video i am using is the Integrated VIA Unichrome Pro AGP Graphics with MPEG-2 accelerator
        Chipset is VIA CN700 & VT8237R.
        Wiindows XP
        Thanks for any help... I have tried the FAQs
        2003 E46 BMW
          Yes, but did you actually install the driver? Not just the automatic driver from window.
            yea... i just tried installing the video (VGA) driver from the EPIA cd... is that the correct thing to do?
            Still the same.
            2003 E46 BMW
              actually after doing that install the video is now a jumpy and shackes
              2003 E46 BMW
                ALSO.... the mouse is not following my finger. I try the allignment and it will not even click on the X. The mouse actually move faster than my finger. If i move my finger one inch the mouse will move all the way across the screen.
                2003 E46 BMW
                  You may try to download the drivers from the VIA website.
                  You could also try to update the bios which can also be found on the via website.
                  The VIA forums may be able to help too.
                  Sorry I can't be more of direct help, but if I can help point the way...
                  Yeah google!
                    thanks for your help.... I am still looking into this.
                    I was able to get the mouse to start in the center of the screen with my finger but when I move my finger to the outside it jumps out there to fast.
                    I dont understand it.
                    2003 E46 BMW
