computer will only power when screen is powered by cig adapter.
  • computer will only power when screen is powered by cig adapter.
    what gives? a fuse? everything works fine, screen flickers quite a bit more than it used to but i have no idea how to troubleshoot this... All i can deduce is that for some reason the cig adapter is completing the circuit. Their never was a problem before. The computer is powered on a direct fused line from the batter and the ground is in the hatch fyi.
    Any help/suggestions greatly appreciated.
    Where is the screen being powered from if it is not the cig lighter? DO you have it hooked to your PSU?
    1.9in x 2.9in -- 47mm x 73mm
      check your wiring again - especially the earths.
      really odd problem. also try discconecting the screen fully as there may be some sort of earth problem with the vga connector.
        That's the only way I power it for now. I had it hooked up to my PSU and then crossed the wires accidently and fried my M1 so im enjoying it working too much/im hesistant to f it up again.
          too much draw?
          if I understand this right, the computer works when you take the screen off of the PSU? that tells me either the screen has something wrong with it (but if it works fine when it's not connected to the PSU then it appears to be fine) or with the screen on the PSU it's pulling too much.
          Are you positive that you have the proper sized PSU and proper sized wires for everything?
          Jan Bennett
            Originally posted by Red GTi VR6 View Post
            too much draw?
            I'm thinking along the same lines.
            What kind of system are you trying to power?
              earths???
              i did try disconnecting the VGA from the back nothing changed. Another thing to note is that if i unplug the screen it completely cuts pc power.
                The ground for your PC is bad. Best I can figure, it's getting little to no connection. It sounds like plugging in the screen is providing ground, which is bad.
                  too much draw?
                  Screen is not powered by the PSU at all.
                  Its the M10000, external cd drive (which i disconnected and it had the same results), usb hub, etc. Modest enough that the M1 can handle it. everything worked fine for two months, using an amp kit, right gauge, right fuses. I think its the car somehow/someway or screen.
                    right it sounds like something like this might be the case, its grounded right to the chasis of the car. how would i begin to solve this?
                      Originally posted by wzcunningham View Post
                      earths???
                      i thought you may say that. does sound like you are earthing through the VGA. keep the screen completely unplugged and check all your earths.
                        im not familiar with the term 'earths'
                          grounds....
                          the ground is earth the earth is ground...now take that and applit it to electrical terms.
                          It's a term the brits use for some reason...
                          Jan Bennett
                            earth = ground. ie the return path.
                            The outer metal of a vga cable connector is the earth. i think your pc may be using this as the return path for the current - maybe not all of it - prossibly just some part of the motherboard. Either way it is bad.
                            Check the ATX connector is in properly. Then check all the drive connectors. Then the wiring on the PSU and then the earth/ground connection of the psu to the chassis. By check i mean give them a proper pull, check screw terminalt are tight, check the continuityu with a meter etc etc. But do it all with the screen unplugged.
                              grounds....
                              hey, we like to use the term Earth is sounds more homely and goes well with our cockney accents, red double decker busses, black cabs and flat caps
