Help! I killed my Lilliput :(
  • Help! I killed my Lilliput :(
    I took it apart, mounted it, put it back together, now I have no power.
    I only unhooked 3 items
    1. the wire that goes to the speaker
    2. The connecter that goes from the screen to the board
    3. the ribbon that controls the buttons
    Thats it!
    When I plug it in I get nothing. I dont have any test equpment. Ive heard mention of a voltmeter, but wouldnt know where to connect it to.
    Any suggestions are greatly appreciated.
    Thanks in advance
    Joe
    01 Solara
    Lilliput 7"
    Jetway 1.5 GHZ C7 mobo
    512 DDR2 533
    M2-ATX, Csetrnc/Morex 2699R
    MPnt GPS
    SD F End
    WiFi
    BlueTooth - not working though
    ALPINE MRP-F250 4/3/2 Channel AMP
    http://www.mp3car.com/vbulletin/show...733#post917733
    do you even get the "no vga signal" message
    Scion CarPC
    Bluetooth Audio Gateway Tutorial
    How to speed up boot with buried features in msconfig
      No. I dont get anything. I'm actually just watching to see if the leds light up. Its like its not getting any power at all. I've checked the connections. everything seems to be in order.
      01 Solara
      Lilliput 7"
      512 DDR2 533
      MPnt GPS
      SD F End
      WiFi
        IMHO, Double check the Button Ribbon cable.
        Be sure you have replugged any ground you could have unscrewed. (If any)
        Is there a led somewhere that will light up when you get power?
        You didnt short anything if you powered it dissambled? did you?
          yea the power led on the left should light up green when it's on, red when it's off, but the ribbon cable has to be plugged in right, you also might want to check the LCD 40pin ribbon (white flat ribbon), if you unplug that cable and get a white screen at least you'll know if you're getting power or not, but be careful with the ribbon i'ts really fragile
          Scion CarPC
            The first time I plugged it in I didnt have the ribbon cable plugged in (for the buttons) Could this have caused a short? I hope not. Is there a way to test for this?
            Thanks for the help
            Joe
            01 Solara
            Lilliput 7"
            512 DDR2 533
            MPnt GPS
            SD F End
            WiFi
              man I did something. I dont know how though. It doesnt seem to be getting ANY power at all. No white screen no leds no nada
              01 Solara
              Lilliput 7"
              512 DDR2 533
              MPnt GPS
              SD F End
              WiFi
                No short if it didnt touch anything metallic while powered.
                Also, some LCD wont light up if the Controls are not connected and/or you wont know that its on because usually the LED is on the same board.
                  the lcd should still work w/o the button board, but without it you wouldn't be able to turn it on, unless you have a 619 like mine and you can program it to auto turn, i've ran mine w/o buttons just fine, i doubt that is the problem
                  Scion CarPC
                    yayy solara! put up some pictures already!!!
                    ok this is not at all a constructive comment whatsoever. sorry.
                    there are a few fuses on the lilli. search a lil and it'll tell you where exactly.
                    if your CCFL does not even turn on(the white light behind the LCD screen) then its pretty much a power issue.
                    99' V6 Solara SE.
                    '05 CBR600RR
                    Baltimore MD.
                    Shuttle XPC| 512MB | 120GB 3.5" Seagate
                    Opus 150W PS | Rikaline 6010 GPS
                    7" Lilliput 619 | Centrafuse | IGuidance 3
                      Pics are coming for sure! I have been taking them throughout the whole process. This was my biggest road block.
                      I'm going to Radio shack today to get a voltmeter. This is the wierdest thing. I havent really done anything major.
                      01 Solara
                      Lilliput 7"
                      512 DDR2 533
                      MPnt GPS
                      SD F End
                      WiFi
                        hey kenpojoe don't feel bad man, i just got the white screen of death, i guess were on the same dammed boat now
                        Scion CarPC
                          ah not being alone has a certain comfort
                          ok I got a Voltmeter to test for current. Any suggestion on what points I should connect too?
                          01 Solara
                          Lilliput 7"
                          512 DDR2 533
                          MPnt GPS
                          SD F End
                          WiFi
                            that part i can't help you with, i can tell you one thing tho, becareful with the converter, it get HOT, i burned my thumb 3 times
                            Scion CarPC
                              EUREKA!!! It was the ribbon cable that connects the buttons. Damn that thing is fussy. I just moved it a bit and POW!
                              So now I'm excited again and I'm going to post my pix.
                              Tomorrow I have to figure out how to make it start automatically. I've seen the re-solder post. Mine is a different model. I'm hoping its the programmable one.
                              Thanks everyone
                              -j
                              01 Solara
                              Lilliput 7"
                              512 DDR2 533
                              MPnt GPS
                              SD F End
                              WiFi
