DigitalWW 700H Monitor Hook-Up?
  • DigitalWW 700H Monitor Hook-Up?
    Well I got my monitor today but the wiring hardness and the manual do not match I don't want to play guess the wires anyone got one hooked up that can give me a clue?
    Manual says
    Green = ground
    Red Battery
    Black= Acc
    Black= Battery -
    My Screen says
    Red=Battery
    Black=Acc
    Green=Ground
    White=Ground
    Help? I want to test it out and install it tonight.
    Do you have actually green and white wires? If yes.. where's the doubt? Use the monitor ones!
      The Issue is/was the manual said to hook it up one way, the screen had a key saying to hook it up a different way and the wires themselves were labled a third way. I have figured it out and it works fine once I got the resoulation and refresh rate correct.
        what refresh rate and resolution are u using ? Mine doesn't show anything when i switch to VGA input.
        04 Accord Coupe Carputer
