ique 3600 lcd help?
  • ique 3600 lcd help?
    I opened up my ique 3600 to replace a battery, and bad things happened. Specifically, the grounding wire (black) for the backlight of the LCD panel came loose.
    The display works, but no backlight anymore. Does anyone have any insight on wiring this display? I could just try things, but I'd rather have real info before beginning. I can do soldering, but knowing what to solder would be useful.
    The other wire dissappears into a crack under the glass. Probably this won't be easy. Ugggggggg.
    Help??
    Ok, does anyone know the manufacturer of this display so that I can look up the specs and figure out where the backlight ground is (and if there's an easier ground that I can access safely?)
